Neff Precision Rolled 0215200317
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200317 is sold in Europe. This same product is sold in North America under part number 7832812 KGF-D-4020-RH-D-KK (FH-4020), Ball Nut Only, FH Style, 40 mm X 20 mm, RH, Flange, Wiper, 0.065 Max Backlash, 52.2 kN Dynamic Load
Part Number 0215200317_4d907_45969806
[B] No
Backlash, Max 0.065 mm
Company Thomson Linear
[D1] 63 mm
D12 No
D13 No
[D4] 78 mm
[D5] 9 mm
[D8] 93 mm
[D8] No
Flange Included
[G] M8x1
[L] 83 mm
[L1] 25 mm
[L10] 7 mm
[L11] No
[L12] No
[L13] No
[L2] 83 mm
[L3] 19.5 mm
[L6] 19.5 mm
[L7] 14 mm
[L8] 70 mm
[L9] 10 mm
Load Lock Included
Maximum Static Load 103.6 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 5.556 mm
Ball Bearing Quantity 156
Diameter Major No
Dynamic Load 52.2 kN
Length No
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
