Neff Precision Rolled 0215200299
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200299 is sold in Europe. This same product is sold in North America under part number 7832821 KGF-D-5020-RH-D-KK (FH-5020), Ball Nut Only, FH Style, 50 mm X 20 mm, RH, Flange, Wiper, 0.084 Max Backlash, 78.8 kN Dynamic Load
Part Number 0215200299_a3806_74185357
[B] No
Backlash, Max 0.084 mm
Company Thomson Linear
[D1] 75 mm
D12 No
D13 No
[D4] 93 mm
[D5] 11 mm
[D8] 110 mm
[D8] No
Flange Included
[G] M8x1
[L] 85 mm
[L1] 16 mm
[L10] 8 mm
[L11] No
[L12] No
[L13] No
[L2] 85 mm
[L3] 22 mm
[L6] 22 mm
[L7] 16 mm
[L8] 85 mm
[L9] 10 mm
Load Lock Included
Maximum Static Load 188.7 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 6.35 mm
Ball Bearing Quantity 164
Diameter Major No
Dynamic Load 78.8 kN
Length No
Screw Diameter,Nominal 50 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
