Neff Precision Rolled 0215200047
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1 – 2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200047 is sold in Europe. This same product is sold in North America under part number KGF-N-1605-RH-EE KGF-N-1605-RH-E-EE, Ball Nut Only, KGF Style, 16 mm X 5 mm, RH, Flange, 0.041 Max Backlash, Steel, 9.3 kN Dynamic Load
Part Number 0215200047_e6309_37004997
[B] No
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 28 mm
D12 No
D13 No
[D4] 38 mm
[D5] 5.5 mm
[D8] 48 mm
[D8] No
Flange Included
[G] M6x1
[L] No
[L1] 8 mm
[L10] 6 mm
[L11] No
[L12] No
[L13] No
[L2] 44 mm
[L3] No
[L6] No
[L7] 12 mm
[L8] No
[L9] 8 mm
Load Lock No
Maximum Static Load 13.1 kN
Preload Optional
Return Style EUS
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper No
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 9.3 kN
Length No
Screw Diameter,Nominal 16 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
