Neff Precision Rolled 0215050345
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm KGM-G-4020-RH-M-KK (ZG-4020), Ball Nut Only, ZG Style, 40 mm X 20 mm, RH, Wiper, 0.18 Max Backlash, 34.2 kN Dynamic Load
Part Number 0215050345_3a089_70112384
[B] No
Backlash, Max 0.18 mm
Company Thomson Linear
[D1] 65 mm
D12 M6x1
D13 6 mm
[D4] No
[D5] No
[D8] No
[D8] No
Flange Sold Seperately
[G] No
[L] 83 mm
[L1] No
[L10] No
[L11] 27 mm
[L12] 10 mm
[L13] 33 mm
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load 57.2 kN
Preload Optional
Return Style Internal
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] M60x2.0
Wiper Included
Ball Bearing Diameter 5.556 mm
Ball Bearing Quantity 80
Diameter Major No
Dynamic Load 34.2 kN
Length No
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
