Neff Precision Rolled 0215050311
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215050311 is sold in Europe. This same product is sold in North America under part number 7832797 KGM-G-3205-RH-E-KK (ZG-3205-MIM), Ball Nut Only, ZG Style, 32 mm X 5 mm, RH, Wiper, 0.09 Max Backlash, 23.3 kN Dynamic Load
Part Number 0215050311_cca86_49901145
[B] No
Backlash, Max 0.09 mm
Company Thomson Linear
[D1] 52 mm
D12 M6x1
D13 5 mm
[D4] No
[D5] No
[D8] No
[D8] No
Flange Sold Seperately
[G] No
[L] 65.5 mm
[L1] No
[L10] No
[L11] 19 mm
[L12] 10.5 mm
[L13] 23 mm
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load 45.5 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] M48x1.5
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 145
Diameter Major No
Dynamic Load 23.3 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
