Neff Precision Rolled 0215050263
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215050263 is sold in Europe. This same product is sold in North America under part number KGM-D-2550-RH-EE KGM-D-2550-RH-D-EE, Ball Nut Only, KGM Style, 25 mm X 50 mm, RH, 0.041 Max Backlash, Steel, 15.4 kN Dynamic Load
Part Number 0215050263_63304_78410314
[B] 5 mm
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 40 mm
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] 1.5 mm
Flange Not Available
[G] No
[L] No
[L1] No
[L10] 20 mm
[L11] No
[L12] No
[L13] No
[L2] 58 mm
[L3] No
[L6] No
[L7] No
[L8] 17 mm
[L9] 19 mm
Load Lock No
Maximum Static Load 31.7 kN
Preload Optional
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia No
[T] 3 mm
[TH] No
Wiper No
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 15.4 kN
Length No
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 50 mm
