Neff Precision Rolled 0215050250
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215050250 is sold in Europe. This same product is sold in North America under part number KGM-N-1205-RH-EE KGM-N-1205-RH-K-00, Ball Nut Only, KGM Style, 12 mm X 5 mm, RH, 0.024 Max Backlash, Steel, 4.4 kN Dynamic Load
Part Number 0215050250_b7504_19629085
[B] 3 mm
Backlash, Max 0.024 mm
Company Thomson Linear
[D1] 20 mm
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] No
Flange Not Available
[G] No
[L] No
[L1] No
[L10] 14 mm
[L11] No
[L12] No
[L13] No
[L2] 24 mm
[L3] No
[L6] No
[L7] No
[L8] No
[L9] 5 mm
Load Lock No
Maximum Static Load 6.8 kN
Preload Optional
Return Style Channel
Rolled/Ground/Whirled No
Root Dia No
[T] 1.8 mm
[TH] No
Wiper No
Ball Bearing Diameter 2 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 4.4 kN
Length No
Screw Diameter,Nominal 12 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
