Neff Precision Rolled 0215050239
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215050239 is sold in Europe. This same product is sold in North America under part number KGM-N-2020-RH-EE KGM-N-2020-RH-D-EE, Ball Nut Only, KGM Style, 20 mm X 20 mm, RH, 0.041 Max Backlash, Steel, 11.6 kN Dynamic Load
Part Number 0215050239_0d405_10012760
[B] 5 mm
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 35 mm
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] 1.5 mm
Flange Not Available
[G] No
[L] No
[L1] No
[L10] 12 mm
[L11] No
[L12] No
[L13] No
[L2] 30 mm
[L3] No
[L6] No
[L7] No
[L8] 11.5 mm
[L9] 9 mm
Load Lock No
Maximum Static Load 18.4 kN
Preload Optional
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia No
[T] 3 mm
[TH] No
Wiper No
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 11.6 kN
Length No
Screw Diameter,Nominal 20 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
