Minature Metric PRM1402
Nut and Screw assembly;Cost-effective solution in a small envelope, ideal for use in small spaces;Clearance held to max .02mm Ball Nut & Screw Assembly, PRM Style, 14 mm X 2 mm, Non-Preloaded, RH, 52 μm/300mm Lead Accuracy, Flange, 0.02 Max Backlash, Steel, 445 mm Long, 3200 N Dynamic Load
Part Number prm1402_bba07_72070854
[A] 26 mm
[B] 25 mm
Backlash, Max 0.02 mm
[BCD] 36 mm
[C] 28 mm
Company Thomson Linear
[D] 45 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] 5.5 mm
[F] 6 mm
Flange Included
[G] 19 mm
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 7500 N
Preload Non-Preloaded
Return Style Return Plate
Rolled/Ground/Whirled No
Root Dia 12.6 mm
[T] No
[TH] No
Ball Bearing Diameter 1.59 mm
Diameter Major No
Dynamic Load 3200 N
Length 445 mm
Screw Diameter,Nominal 14 mm
Standard Lead Accuracy ± 52 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 2 mm
