Minature Metric PRM1015
Nut and Screw assembly;Cost-effective solution in a small envelope, ideal for use in small spaces;Clearance held to max .02mm Ball Nut & Screw Assembly, PRM Style, 10 mm X 15 mm, Non-Preloaded, RH, 52 μm/300mm Lead Accuracy, Flange, 0.02 Max Backlash, Steel, 405 mm Long, 3300 N Dynamic Load
Part Number prm1015_7d204_87103300
[A] 23 mm
[B] 33 mm
Backlash, Max 0.02 mm
[BCD] 32 mm
[C] 25 mm
Company Thomson Linear
[D] 40 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] 4.5 mm
[F] 5 mm
Flange Included
[G] 22 mm
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 6400 N
Preload Non-Preloaded
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia 8.4 mm
[T] No
[TH] No
Ball Bearing Diameter 2 mm
Diameter Major No
Dynamic Load 3300 N
Length 405 mm
Screw Diameter,Nominal 10 mm
Standard Lead Accuracy ± 52 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 15 mm
