Minature Metric PRM0812
Nut and Screw assembly;Cost-effective solution in a small envelope, ideal for use in small spaces;Clearance held to max .02mm Ball Nut & Screw Assembly, PRM Style, 8 mm X 12 mm, Non-Preloaded, RH, 52 μm/300mm Lead Accuracy, Flange, 0.02 Max Backlash, Steel, 360 mm Long, 2200 N Dynamic Load
Part Number prm0812_3ab84_45025931
[A] 18 mm
[B] 27 mm
Backlash, Max 0.02 mm
[BCD] 25 mm
[C] 20 mm
Company Thomson Linear
[D] 31 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] 3.4 mm
[F] 4 mm
Flange Included
[G] 17 mm
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 4000 N
Preload Non-Preloaded
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia 6.7 mm
[T] No
[TH] No
Ball Bearing Diameter 1.59 mm
Diameter Major No
Dynamic Load 2200 N
Length 360 mm
Screw Diameter,Nominal 8 mm
Standard Lead Accuracy ± 52 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 12 mm
