Minature Metric PRM0801
Nut and Screw assembly;Cost-effective solution in a small envelope, ideal for use in small spaces;Clearance held to max .02mm Ball Nut & Screw Assembly, PRM Style, 8 mm X 1 mm, Non-Preloaded, RH, 52 μm/300mm Lead Accuracy, Flange, 0.02 Max Backlash, Steel, 360 mm Long, 780 N Dynamic Load
Part Number prm0801_2f002_18522628
[A] 16 mm
[B] 17 mm
Backlash, Max 0.02 mm
[BCD] 23 mm
[C] 18 mm
Company Thomson Linear
[D] 29 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] 3.4 mm
[F] 4 mm
Flange Included
[G] 13 mm
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 1650 N
Preload Non-Preloaded
Return Style Return Plate
Rolled/Ground/Whirled No
Root Dia 7.3 mm
[T] No
[TH] No
Ball Bearing Diameter 0.8 mm
Diameter Major No
Dynamic Load 780 N
Length 360 mm
Screw Diameter,Nominal 8 mm
Standard Lead Accuracy ± 52 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 1 mm
