Minature Metric PRM0601
Nut and Screw assembly;Cost-effective solution in a small envelope, ideal for use in small spaces;Clearance held to max .02mm Ball Nut & Screw Assembly, PRM Style, 6 mm X 1 mm, Non-Preloaded, RH, 52 μm/300mm Lead Accuracy, Flange, 0.02 Max Backlash, Steel, 265 mm Long, 680 N Dynamic Load
Part Number prm0601_fc388_02052475
[A] 13 mm
[B] 17 mm
Backlash, Max 0.02 mm
[BCD] 20 mm
[C] 16 mm
Company Thomson Linear
[D] 26 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] 3.4 mm
[F] 4 mm
Flange Included
[G] 13 mm
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 1200 N
Preload Non-Preloaded
Return Style Return Plate
Rolled/Ground/Whirled No
Root Dia 5.3 mm
[T] No
[TH] No
Ball Bearing Diameter 0.8 mm
Diameter Major No
Dynamic Load 680 N
Length 265 mm
Screw Diameter,Nominal 6 mm
Standard Lead Accuracy ± 52 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 1 mm
