Minature Metric PRM0401
Nut and Screw assembly;Cost-effective solution in a small envelope, ideal for use in small spaces;Clearance held to max .02mm Ball Nut & Screw Assembly, PRM Style, 4 mm X 1 mm, Non-Preloaded, RH, 52 μm/300mm Lead Accuracy, Flange, 0.02 Max Backlash, Steel, 100 mm Long, 560 N Dynamic Load
Part Number prm0401_e8b04_61449253
[A] 11 mm
[B] 17 mm
Backlash, Max 0.02 mm
[BCD] 18 mm
[C] 15 mm
Company Thomson Linear
[D] 24 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] 3.4 mm
[F] 4 mm
Flange Included
[G] 13 mm
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 790 N
Preload Non-Preloaded
Return Style Return Plate
Rolled/Ground/Whirled No
Root Dia 3.3 mm
[T] No
[TH] No
Ball Bearing Diameter 0.8 mm
Diameter Major No
Dynamic Load 560 N
Length 100 mm
Screw Diameter,Nominal 4 mm
Standard Lead Accuracy ± 52 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 1 mm
