Minature Metric 8105-448-060
Nut Only, Screw Sold Separately Ball Nut Only, RSI Style, 14 mm X 3 mm, RH, 0.05 Max Backlash, 6.7 kN Dynamic Load
Part Number 8105_448_060_b7b87_92448530
[A] No
[B] 4 mm
Backlash, Max 0.05 mm
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] 30 mm
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange Not Available
[G] No
[L] 35 mm
[L1] No
[L10] 19 mm
[L2] No
[L7] No
[L8] No
Maximum Static Load 11.6 kN
Preload Optional
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] 2.5 mm
[TH] No
Ball Bearing Diameter 1.984 mm
Diameter Major No
Dynamic Load 6.7 kN
Length No
Screw Diameter,Nominal 14 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 3 mm
