Minature Metric 8105-448-059
Nut Only, Screw Sold Separately Ball Nut Only, RSI Style, 12 mm X 5 mm, RH, 0.05 Max Backlash
Part Number 8105_448_059_e4c86_49583132
[A] No
[B] No
Backlash, Max 0.05 mm
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] No
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange Not Available
[G] No
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load No
Preload Optional
Return Style No
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Ball Bearing Diameter No
Diameter Major No
Dynamic Load No
Length No
Screw Diameter,Nominal 12 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
