Minature Metric 8105-448-047
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 14 mm X 3 mm, RH, Flange, 0.08 Max Backlash, 6.7 kN Dynamic Load
Part Number 8105_448_047_afe87_82547392
[A] No
[B] No
Backlash, Max 0.08 mm
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] 24 mm
[D4] 36 mm
[D5] 5.5 mm
[D8] 45 mm
[E] No
[F] No
Flange Included
[G] No
[L] No
[L1] No
[L10] No
[L2] 35 mm
[L7] 8 mm
[L8] 28 mm
Maximum Static Load 11.6 kN
Preload Optional
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Ball Bearing Diameter 1.984 mm
Diameter Major No
Dynamic Load 6.7 kN
Length No
Screw Diameter,Nominal 14 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 3 mm
