Minature Metric 8105-448-033
Nut Only, Screw Sold Separately TSI-N-1403-RH-M-M-00 (14mm x 3mm)
Part Number 8105_448_033_ac005_19842202
[A] No
[B] No
Backlash, Max 0.1 mm
[BCD] No
[C] No
Company Thomson Linear
[D] 30 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange Not Available
[G] No
[L] 35 mm
[L1] 9 mm
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 11.6 kN
Preload Non-Preloaded
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] M24x1.5
Ball Bearing Diameter 1.984 mm
Diameter Major No
Dynamic Load 6.7 kN
Length No
Screw Diameter,Nominal 14 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 3 mm
