Minature Metric 8103-448-055
Nut Only, Screw Sold Separately Ball Nut Only, RSI Style, 10 mm X 10 mm, RH, 0.05 Max Backlash, 4.1 kN Dynamic Load
Part Number 8103_448_055_75502_92771317
[A] No
[B] 3 mm
Backlash, Max 0.05 mm
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] 23 mm
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange Not Available
[G] No
[L] 35 mm
[L1] No
[L10] 13 mm
[L2] No
[L7] No
[L8] No
Maximum Static Load 5.8 kN
Preload Optional
Return Style Channel
Rolled/Ground/Whirled No
Root Dia No
[T] 2 mm
[TH] No
Ball Bearing Diameter 1.984 mm
Diameter Major No
Dynamic Load 4.1 kN
Length No
Screw Diameter,Nominal 10 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
