Minature Metric 8103-448-039
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 10 mm X 2 mm, RH, Flange, 0.08 Max Backlash, 2.7 kN Dynamic Load
Part Number 8103_448_039_5de09_25506554
[A] No
[B] No
Backlash, Max 0.08 mm
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] 18 mm
[D4] 28 mm
[D5] 4.5 mm
[D8] 36 mm
[E] No
[F] No
Flange Included
[G] No
[L] No
[L1] No
[L10] No
[L2] 22 mm
[L7] 6 mm
[L8] 22 mm
Maximum Static Load 3.8 kN
Preload Optional
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Ball Bearing Diameter 1.588 mm
Diameter Major No
Dynamic Load 2.7 kN
Length No
Screw Diameter,Nominal 10 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 2 mm
