Minature Metric 8103-448-037
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 8 mm X 2.5 mm, RH, Flange, 0.08 Max Backlash, 3.1 kN Dynamic Load
Part Number 8103_448_037_1b788_43308811
[A] No
[B] No
Backlash, Max 0.08 mm
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] 16 mm
[D4] 22 mm
[D5] 3.4 mm
[D8] 28 mm
[E] No
[F] No
Flange Included
[G] No
[L] No
[L1] No
[L10] No
[L2] 24 mm
[L7] 6 mm
[L8] 19 mm
Maximum Static Load 4 kN
Preload Optional
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Ball Bearing Diameter 1.588 mm
Diameter Major No
Dynamic Load 3.1 kN
Length No
Screw Diameter,Nominal 8 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 2.5 mm
