Minature Metric 8103-448-027
Nut Only, Screw Sold Separately TSI-N-0802.5-RH-M-M-00 (8mm x 2.5mm)
Part Number 8103_448_027_13a88_74079274
[A] No
[B] No
Backlash, Max 0.1 mm
[BCD] No
[C] No
Company Thomson Linear
[D] 18 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange Not Available
[G] No
[L] 24 mm
[L1] 8 mm
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 4 kN
Preload Non-Preloaded
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] M15x1
Ball Bearing Diameter 1.588 mm
Diameter Major No
Dynamic Load 3.1 kN
Length No
Screw Diameter,Nominal 8 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 2.5 mm
