Minature Metric 8103-448-022
Nut Only, Screw Sold Separately TSI-N-1002-RH-M-M-00 (10mm x 2mm)
Part Number 8103_448_022_4a583_13310926
[A] No
[B] No
Backlash, Max 0.1 mm
[BCD] No
[C] No
Company Thomson Linear
[D] 19.5 mm
[D1] No
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange Not Available
[G] No
[L] 22 mm
[L1] 8 mm
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load 3.8 kN
Preload Non-Preloaded
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] M17x1
Ball Bearing Diameter 1.588 mm
Diameter Major No
Dynamic Load 2.7 kN
Length No
Screw Diameter,Nominal 10 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 2 mm
