Minature Metric 8102-448-048
Nut Only, Screw Sold Separately Ball Nut Only, RSI Style, 6 mm X 2 mm, RH, 0.05 Max Backlash, 1.6 kN Dynamic Load
Part Number 8102_448_048_f8509_14348514
[A] No
[B] 2 mm
Backlash, Max 0.05 mm
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] 16 mm
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange Not Available
[G] No
[L] 22 mm
[L1] No
[L10] 10 mm
[L2] No
[L7] No
[L8] No
Maximum Static Load 2.1 kN
Preload Optional
Return Style Multi Liner
Rolled/Ground/Whirled No
Root Dia No
[T] 1.2 mm
[TH] No
Ball Bearing Diameter 1 mm
Diameter Major No
Dynamic Load 1.6 kN
Length No
Screw Diameter,Nominal 6 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 2 mm
