Minature Metric 190-9687
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with ball nuts and/or support bearings.;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, Miniature Style, 8 mm X 3 mm, RH, 52 μm/300mm Lead Accuracy, 1500 mm Long
Part Number 190_9687_0bd82_05602267
[A] No
[B] No
Backlash, Max No
[BCD] No
[C] No
Company Thomson Linear
[D] No
[D1] No
[D4] No
[D5] No
[D8] No
[E] No
[F] No
Flange No
[G] No
[L] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load No
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia 5.9 mm
[T] No
[TH] No
Ball Bearing Diameter 1.984 mm
Diameter Major 7.7 mm
Dynamic Load No
Length 1500 mm
Screw Diameter,Nominal 8 mm
Standard Lead Accuracy ± 52 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 3 mm
