MAE3 Absolute Magnetic Kit Encoder
The MAE3 is an absolute magnetic kit encoder that provides shaft position information over 360° of rotation with no stops or gaps. This magnetic encoder is designed to easily mount to, and dismount from, an existing shaft to provide digital feedback information. The MAE3 is available with an analog or a pulse width modulated (PWM) digital output.
Analog output provides an analog voltage that is proportional to the absolute shaft position. Analog output is only available in 10-bit resolution.
PWM output provides a pulse width duty cycle that is proportional to the absolute shaft position. PWM output is available in 10-bit and 12-bit resolutions. While the accuracy is the same for both encoders the 12-bit version provides higher resolution.
The MAE3 consists of three components: base, push-on magnetic hub, and encoder body. The base will accommodate 0.750", 1.280" and 1.812" mounting bolt circles. No tools are needed for the push-on, collet gripping hub. The hub mounts to a standard shaft in seconds and provides a simple and reliable means of securing the magnet to the shaft.
Two 4-40 pan head screws secure the base and encoder body to any flat surface. If desired, the encoder can be powered up and rotated by hand to any desired absolute position before the screws are tightened.
Connecting to the MAE3 is simple. The 3-pin, high retention, snap-in 1.25mm pitch polarized connector provides for +5V, output, and ground. Quick, simple assembly and disassembly -40C to +125C operating temperature Accepts ± .025" axial shaft play Mounts to 0.750", 1.280" and 1.812" bolt circles Fits shaft diameters from .125" to .250" or 2mm to 6mm 10-bit Analog output - 2.6 kHz sampling rate 10-bit PWM output - 1,024 positions per revolution, 1 kHz 12-bit PWM output - 4,096 positions per revolution, 250 Hz
Part Number mae3_absolute_magnetic
Company US Digital
Electrostatic Discharge, Human Body ModelMIL-STD-883E, Method 3015.7 ± 2 kV
Electrostatic Discharge, IEC 61000-4-2 ± 2 kV
Humidity, Non-condensing 5% to 85%
Storage Temperature No
Vibration (5Hz to 2kHz), G 20
Operating Temperature, C -40 to +125
