MA3 Miniature Absolute Magnetic Shaft Encoder
The MA3 is a miniature rotary absolute shaft encoder that reports the shaft position over 360° with no stops or gaps. The MA3 is available with an analog or a pulse width modulated (PWM) digital output.     Analog output provides an analog voltage that is proportional to the absolute shaft position. Analog output is only available in 10-bit resolution.PWM output provides a pulse width duty cycle that is proportional to the absolute shaft position. PWM output is available in 10-bit and 12-bit resolutions. While the accuracy is the same for both encoders, the 12-bit version provides higher resolution.Three shaft torque versions are available. The standard torque version has a sleeve bushing lubricated with a viscous motion control gel to provide torque and feel that is ideal for front panel human interface applications.The no torque added option has a sleeve bushing and a low viscosity lubricant (that does not intentionally add torque) for low RPM applications where a small amount of torque is acceptable.The ball bearing version uses miniature precision ball bearings that are suitable for high speed and ultra low torque applications. The shaft diameter for ball bearing version option is 1/8" rather than 1/4".Connecting to the MA3 is simple. The 3-pin high retention snap-in 1.25mm pitch polarized connector provides for +5V, output, and ground. Miniature size (0.48" diameter) Non-contacting magnetic single chip sensing technology -40C to 125C operating temperature range 10-bit Analog output - 2.6 kHz sampling rate 10-bit PWM output - 1,024 positions per revolution, 1 kHz 12-bit PWM output - 4,096 positions per revolution, 250 Hz
Part Number ma3_miniature_absolute
Company US Digital
Electrostatic Discharge, Human Body ModelMIL-STD-883E, Method 3015.7 No
Electrostatic Discharge, IEC 61000-4-2 ± 2 kV
Humidity, Non-condensing 5% to 85%
Storage Temperature No
Vibration (5Hz to 2kHz), G 20
Operating Temperature, C -40 to +125
