J0200-352-4-000 - 60mm Servo Motor, 200W, with Brake
High performance brushless AC servo motor with brake. Standard configuration includes high-resolution, incremental encoder feedback. This motor is UL Recognized in the US and Canada, file no. E472271.
High torque density
Low rotor inertia
Compact size
High-resolution, incremental encoders (2500 lines, 10000 counts)
Brake
IP65 rated for harsh environments
Company Applied Motion
Part Number j0200_352_4_000_60mm_servo_m
Armature Inductance 25 Line-to-Line mH
Armature Resistance 8.6 Line-to-Line ohms
Concentricity 015 inches
Continuous Torque 5.66 in-lb
Frame Size 60 mm
Insulation Class Class B (130 C)
Integral Holding Brake Yes
Maximum Radial Load 45 lbs
Maximum Thrust Load 15 lbs
Motor Length 5.45 inch
Operating Temperature 0 to 40 C
Part Number J0200-352-4-000
Peak Current 4.5 A rms
Peak Speed 6000 rpm
Peak Torque 16.8 in-lb
Perpendicularity 015 inches
Rated Current 1.5 A rms
Rated Power 200 watts
Rated Speed 3000 rpm
Rated Voltage 220 VAC
Rotor Inertia 031154 oz-in-sec2
Shaft Diameter 14 mm (0.551 inch)
Storage Temperature -20 to 80 C
Torque Constant 3.8 in-lb/A
Voltage Constant 27.2 V/krpm
