J0200-304-4-000 - 60mm Servo Motor, 200W
High performance brushless AC servo motor. Standard configuration includes high-resolution, incremental encoder feedback. This motor is UL Recognized in the US and Canada, file no. E472271.
High torque density
Low rotor inertia
Compact size
High-resolution, incremental encoders (2500 lines, 10000 counts)
IP65 rated for harsh environments
Company Applied Motion
Part Number j0200_304_4_000_60mm_servo_m
Armature Inductance 2 Line-to-Line mH
Armature Resistance 0.67 Line-to-Line ohms
Concentricity 015 inches
Continuous Torque 5.66 in-lb
Frame Size 60 mm
Insulation Class Class B (130 C)
Integral Holding Brake No
Maximum Radial Load 45 lbs
Maximum Thrust Load 15 lbs
Motor Length 4.17 inch
Operating Temperature 0 to 40 C
Part Number J0200-304-4-000
Peak Current 15.6 A rms
Peak Speed 6000 rpm
Peak Torque 16.8 in-lb
Perpendicularity 015 inches
Rated Current 5.2 A rms
Rated Power 200 watts
Rated Speed 3000 rpm
Rated Voltage 48 VDC
Rotor Inertia 023365 oz-in-sec2
Shaft Diameter 14 mm (0.551 inch)
Storage Temperature -20 to 80 C
Torque Constant 1.10 in-lb/A
Voltage Constant 7.9 V/krpm
