J0100-351-3-000 - 40mm Servo Motor, 100W, with Brake
High performance brushless AC servo motor with brake. Standard configuration includes high-resolution, incremental encoder feedback. This motor is UL Recognized in the US and Canada, file no. E472271.
High torque density
Low rotor inertia
Compact size
High-resolution, incremental encoders (2500 lines, 10000 counts)
Brake
IP65 rated for harsh environments
Company Applied Motion
Part Number j0100_351_3_000_40mm_servo_m
Armature Inductance 5.9 Line-to-Line mH
Armature Resistance 4.9 Line-to-Line ohms
Concentricity 015 inches
Continuous Torque 2.83 in-lb
Frame Size 40 mm
Insulation Class Class B (130 C)
Integral Holding Brake Yes
Maximum Radial Load 13.5 lbs
Maximum Thrust Load 11 lbs
Motor Length 5.82 inch
Operating Temperature 0 to 40 C
Part Number J0100-351-3-000
Peak Current 4.95 A rms
Peak Speed 6000 rpm
Peak Torque 8.14 in-lb
Perpendicularity 015 inches
Rated Current 1.65 A rms
Rated Power 100 watts
Rated Speed 3000 rpm
Rated Voltage 120 VAC
Rotor Inertia 00699 oz-in-sec2
Shaft Diameter 8 mm (0.315 inch)
Storage Temperature -20 to 80 C
Torque Constant 1.72 in-lb/A
Voltage Constant 12 V/krpm
