J0100-303-3-000 - 40mm Servo Motor, 100W
High performance brushless AC servo motor. Standard configuration includes high-resolution, incremental encoder feedback. This motor is UL Recognized in the US and Canada, file no. E472271.
High torque density
Low rotor inertia
Compact size
High-resolution, incremental encoders (2500 lines, 10000 counts)
IP65 rated for harsh environments
Company Applied Motion
Part Number j0100_303_3_000_40mm_servo_m
Armature Inductance 0.58 Line-to-Line mH
Armature Resistance 0.48 Line-to-Line ohms
Concentricity 015 inches
Continuous Torque 2.83 in-lb
Frame Size 40 mm
Insulation Class Class B (130 C)
Integral Holding Brake No
Maximum Radial Load 13.5 lbs
Maximum Thrust Load 11 lbs
Motor Length 4.33 inch
Operating Temperature 0 to 40 C
Part Number J0100-303-3-000
Peak Current 15.6 A rms
Peak Speed 6000 rpm
Peak Torque 8.5 in-lb
Perpendicularity 015 inches
Rated Current 5.2 A rms
Rated Power 100 watts
Rated Speed 3000 rpm
Rated Voltage 24 VDC
Rotor Inertia 00606 oz-in-sec2
Shaft Diameter 8 mm (0.315 inch)
Storage Temperature -20 to 80 C
Torque Constant .54 in-lb/A
Voltage Constant 3.8 V/krpm
