HT23-603 - NEMA 23 High Torque Step Motor, 354 oz-in
The HT23-603 two-phase stepper motor is suitable for a wide range of motion control applications. Terminated with 8 motor leads, the motor can be connected in a few different ways, including bipolar series and bipolar parallel.Holding Brake, optionalTo order this motor with the optional holding brake select the part number HT23-603B. The motor ships with a 24-volt holding brake mounted to the rear of the motor, as shown in the picture below. The holding brake and encoder options cannot be ordered on the same motor.
2-phase hybrid step motor
High torque design
Standard NEMA 23 dimensions
Series or parallel wiring
Optimized for microstepping
Company Applied Motion
Part Number ht23_603_nema_23_high_torque
Bipolar Holding Torque 354 oz-in
Bipolar Parallel Current 5.0 A/phase
Bipolar Parallel Inductance 2.2 mH/phase
Bipolar Parallel Resistance 0.5 Ohms/phase
Concentricity 02 inches
End Play No
Frame Size NEMA 23
Insulation Class Class B (130 C)
Integral Gearhead No
Lead Wire Cable Length 18 inches
Lead Wire Configuration flying leads, no connector
Lead Wire Gauge 22 AWG
Maximum Radial Load 17 lbs
Maximum Thrust Load 3.4 lbs
Motor Length 4.37 inches
Motor Type High torque
Number Of Lead Wires 8
Operating Temperature -20 to 50 C
Part Number HT23-603
Part Number w/Double Shaft  HT23-603D
Perpendicularity 04 inches
Radial Play 008 inch max w/ 1.1 lb load
Rotor Inertia 1.06E-02 oz-in-sec2
Shaft Diameter 6.35 mm (0.250 inch)
Shaft Run Out 02 inch T.I.R. max
Step Angle 1.8 deg
Storage Temperature -30 to 70 C
