HD25 Industrial Rugged Metal Optical Encoder
The HD25 is a rugged optical incremental shaft encoder designed for heavy-duty industrial applications. The housing, machined from a solid billet aluminum block and finished with clear anodizing, conforms to the industrial standard size 25 package. Size 25 encoders are widely used and are considered to be the backbone of feedback devices found in factory automation and industrial applications. The HD25 will drop directly into existing applications to provide a superior solution at a competitive cost. The HD25 is a factory stock product with little or no lead-time.     Our absolute encoders may be used in many stand alone applications that do not require a PC interface. For these applications we provide detailed communications protocols for all of our absolute products. NEMA size 25 package Anodized milled aluminum housing with O-ring housing seal LED and phased array wide-gap monolithic encoder technology 64 to 10,000 cycles per revolution (CPR) 256 to 40,000 pulses per revolution (PPR) 2 channel quadrature squarewave outputs Single-ended or differential outputs Optional index (3rd channel)
Part Number hd25_industrial_rugged
Company US Digital
Operating Temperature (CPR < 2000), C No
Operating Temperature (CPR ≥ 2000), C No
Operating Temperature (CPR < 3600), C -40 to 100
Operating Temperature (CPR ≥ 3600), C -25 to 100
Supply Voltage, V 4.5 to 5.5
Vibration (5Hz to 2kHz), G 20
Weight Oz 17
Max. Acceleration, rad/sec2 100000
