H3 Ball Bearing Optical Shaft Encoder
The H3 series ball bearing optical shaft encoder has a molded plastic, glass-filled enclosure, which utilizes a 5-pin standard connector. This non-contacting rotary to digital converter is designed to provide digital feedback information.
The H3 is fully assembled with a brass shaft, two 1/4" ID by 1/2" OD ball bearings and a mounting plate. The mounting plate comes with two mounting holes for screws #4 or smaller.The H3 is normally designed for applications of 10 feet or less. For longer cable lengths, adding a PC4/PC5 differential line driver is recommended.
A connection to the H3 series encoder is made through a 5-pin standard connector (sold separately). The mating connectors are available from US Digital® with several cable options and lengths.  Ball bearing option tracks to 10,000 RPM 2-channel quadrature, TTL squarewave outputs 3rd channel index option available on some resolutions 32 to 10,000 cycles per revolution (CPR) 128 to 20,000 pulses per revolution (PPR) Wide operating temperature Single +5VDC supply
Part Number h3_ball_bearing_optical
Company US Digital
Operating Temperature (CPR < 2000), C No
Operating Temperature (CPR ≥ 2000), C No
Operating Temperature (CPR < 3600), C -40 to 100
Operating Temperature (CPR ≥ 3600), C -25 to 100
Supply Voltage, V 4.5 to 5.5
Vibration (5Hz to 2kHz), G 20
Weight Oz 2.69
Max. Acceleration, rad/sec2 100000
