Goldline® S Series Submersible Servo Motors S-60x
These brushless servo motors incorporate pressure compensation technology to allow underwater operation up to 20,000 ft while withstanding extreme environments. They feature stainless steel and aluminum nickel bronze housings or an anodized aluminum housing for lighter overall weight. All shafts are stainless steel and sealed with an externally serviceable O-ring seal. The S Series is fully tooled for cost-effective volume production.
Choice of stainless steel and aluminum nickel bronze housings or an anodized aluminum housing for lighter overall weight
Stainless steel shaft with externally serviceable seal
NEMA mounts
Resolver feedback
SEACON connectors
Pressure compensated: 10,000 psi
Flying lead connections
Designed to withstand severe shock and extreme environments
Part Number goldline®_s_series_submersible_servo_motors_s-60x
Stack Length 2,4,6
Windings A,B
Max BUS (VDC) 320
Max Stall Tc Nm (lb-in) 89.52 (792.3)
Max Tp Nm (lb-in) 131.83 (1167)
Max Rated N 2950
Max Rated Power @ Max BUS kW (Hp) 16.86 (23)
Pressure Compensated psi (depth, ft.) 10,000 (20,000)
Company Kollmorgen
