FSI - 16mm - 50mm TH_BS_TSI_Screw_FSI
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with ball nuts and/or support bearings.;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly.
Part Number th_bs_tsi_screw_fsi_6ab80_0562
Backlash, Max No
Company Thomson Linear
[D1] No
[D4] No
[D5] No
[D8] No
Flange No
[G] No
[L1] No
[L10] No
[L2] No
[L7] No
[L8] No
Maximum Static Load No
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Ball Bearing Diameter No
Dynamic Load No
Screw Diameter,Nominal No
Standard Lead Accuracy ± 23 μm/300mm
Thread Direction RH
Travel Per Shaft Rev No
