FSI - 16mm - 50mm 7120-448-077
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 50 mm X 10 mm, RH, Flange, 0.08 Max Backlash, 68.7 kN Dynamic Load
Part Number 7120_448_077_95b03_91834961
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 75 mm
[D4] 93 mm
[D5] 11 mm
[D8] 110 mm
Flange Included
[G] M8
[L1] 16 mm
[L10] 8 mm
[L2] 95 mm
[L7] 14 mm
[L8] 85 mm
Maximum Static Load 155.8 kN
Preload Optional
Return Style Single Liner
Rolled/Ground/Whirled No
Ball Bearing Diameter 7.144 mm
Dynamic Load 68.7 kN
Screw Diameter,Nominal 50 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
