FSI - 16mm - 50mm 7115-448-075
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 40 mm X 20 mm, RH, Flange, 0.08 Max Backlash, 33.3 kN Dynamic Load
Part Number 7115_448_075_91c86_44532534
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 63 mm
[D4] 78 mm
[D5] 9 mm
[D8] 93 mm
Flange Included
[G] M8
[L1] 16 mm
[L10] 7 mm
[L2] 80 mm
[L7] 14 mm
[L8] 70 mm
Maximum Static Load 76.1 kN
Preload Optional
Return Style Channel
Rolled/Ground/Whirled No
Ball Bearing Diameter 5 mm
Dynamic Load 33.3 kN
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
