FSI - 16mm - 50mm 7112-448-070
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 32 mm X 10 mm, RH, Flange, 0.08 Max Backlash, 33.4 kN Dynamic Load
Part Number 7112_448_070_82283_32872233
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 53 mm
[D4] 65 mm
[D5] 9 mm
[D8] 80 mm
Flange Included
[G] M8x1
[L1] 16 mm
[L10] 6 mm
[L2] 69 mm
[L7] 12 mm
[L8] 62 mm
Maximum Static Load 54.5 kN
Preload Optional
Return Style Single Liner
Rolled/Ground/Whirled No
Ball Bearing Diameter 7.144 mm
Dynamic Load 33.4 kN
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
