FSI - 16mm - 50mm 7110-448-065
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 25 mm X 10 mm, RH, Flange, 0.08 Max Backlash, 13.2 kN Dynamic Load
Part Number 7110_448_065_76705_88948756
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 40 mm
[D4] 51 mm
[D5] 7 mm
[D8] 62 mm
Flange Included
[G] M6
[L1] 16 mm
[L10] 5 mm
[L2] 55 mm
[L7] 10 mm
[L8] 48 mm
Maximum Static Load 25.3 kN
Preload Optional
Return Style Channel
Rolled/Ground/Whirled No
Ball Bearing Diameter 3.5 mm
Dynamic Load 13.2 kN
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
