FSI - 16mm - 50mm 7107-448-063
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 20 mm X 5 mm, RH, Flange, 0.08 Max Backlash, 10.5 kN Dynamic Load
Part Number 7107_448_063_72889_57287570
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 36 mm
[D4] 47 mm
[D5] 7 mm
[D8] 58 mm
Flange Included
[G] M6x1
[L1] 10 mm
[L10] 5 mm
[L2] 42 mm
[L7] 10 mm
[L8] 44 mm
Maximum Static Load 16.6 kN
Preload Optional
Return Style Channel
Rolled/Ground/Whirled No
Ball Bearing Diameter 3.5 mm
Dynamic Load 10.5 kN
Screw Diameter,Nominal 20 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
