FSI - 16mm - 50mm 7106-448-062
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 16 mm X 10 mm, RH, Flange, 0.08 Max Backlash, 15.4 kN Dynamic Load
Part Number 7106_448_062_72886_76583811
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 28 mm
[D4] 38 mm
[D5] 6 mm
[D8] 48 mm
Flange Included
[G] M6x1
[L1] 10 mm
[L10] 5 mm
[L2] 55 mm
[L7] 10 mm
[L8] 40 mm
Maximum Static Load 26.5 kN
Preload Optional
Return Style Channel
Rolled/Ground/Whirled No
Ball Bearing Diameter 3 mm
Dynamic Load 15.4 kN
Screw Diameter,Nominal 16 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
