FSI - 16mm - 50mm 7106-448-061
Nut Only, Screw Sold Separately Ball Nut Only, FSI Style, 16 mm X 5 mm, RH, Flange, 0.08 Max Backlash, 9.3 kN Dynamic Load
Part Number 7106_448_061_6ea01_72459687
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 28 mm
[D4] 38 mm
[D5] 6 mm
[D8] 48 mm
Flange Included
[G] M6x1
[L1] 10 mm
[L10] 5 mm
[L2] 42 mm
[L7] 10 mm
[L8] 40 mm
Maximum Static Load 13.1 kN
Preload Optional
Return Style Single Liner
Rolled/Ground/Whirled No
Ball Bearing Diameter 3.5 mm
Dynamic Load 9.3 kN
Screw Diameter,Nominal 16 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
