FineLine Precision Rolled 7833300
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7833300 is sold in North America. This same product is sold in Europe under part number 0215200232 Ball Nut Only, FH Style, 32 mm X 32 mm, RH, Flange, Wiper, 0.08 Max Backlash, 19.7 kN Dynamic Load
Part Number 7833300_32e82_69182824
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 56 mm
[D4] 71 mm
[D5] 9 mm
[D8] 86 mm
Flange Included
[G] M6x1
[L] 42 mm
[L1] 12 mm
[L10] 6 mm
[L2] 42 mm
[L3] 9 mm
[L6] 9 mm
[L7] 12 mm
[L8] 68 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 39 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 3.969 mm
Ball Bearing Quantity 124
Diameter Major No
Dynamic Load 19.7 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 32 mm
