FineLine Precision Rolled 7832826
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832826 is sold in North America. This same product is sold in Europe under part number 0215200325 Ball Nut Only, FH Style, 63 mm X 20 mm, RH, Flange, Wiper, 0.18 Max Backlash, 103.1 kN Dynamic Load
Part Number 7832826_65b09_87893838
Backlash, Max 0.18 mm
Company Thomson Linear
[D1] 95 mm
[D4] 115 mm
[D5] 13.5 mm
[D8] 135 mm
Flange Included
[G] M8x1
[L] 86 mm
[L1] 18 mm
[L10] 10 mm
[L2] 86 mm
[L3] 24 mm
[L6] 24 mm
[L7] 20 mm
[L8] 100 mm
[L9] 10 mm
Load Lock Included
Maximum Static Load 270.8 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 7.144 mm
Ball Bearing Quantity 186
Diameter Major No
Dynamic Load 103.1 kN
Length No
Screw Diameter,Nominal 63 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
