FineLine Precision Rolled 7832823
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832823 is sold in North America. This same product is sold in Europe under part number 0215200279 Ball Nut Only, FK Style, 63 mm X 10 mm, Non-Preloaded, RH, Flange, 0.18 Max Backlash, 93.8 kN Dynamic Load
Part Number 7832823_61c87_10603629
Backlash, Max 0.18 mm
Company Thomson Linear
[D1] 90 mm
[D4] 108 mm
[D5] 11 mm
[D8] 125 mm
Flange Included
[G] M8x1
[L] 103.5 mm
[L1] 16 mm
[L10] 9 mm
[L2] 103.5 mm
[L3] 7 mm
[L6] 7 mm
[L7] 18 mm
[L8] 95 mm
[L9] 10 mm
Load Lock No
Maximum Static Load 229.7 kN
Preload Non-Preloaded
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper No
Ball Bearing Diameter 7.144 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 93.8 kN
Length No
Screw Diameter,Nominal 63 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
