FineLine Precision Rolled 7832821
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832821 is sold in North America. This same product is sold in Europe under part number 0215200299 Ball Nut Only, FH Style, 50 mm X 20 mm, RH, Flange, Wiper, 0.16 Max Backlash, 78.8 kN Dynamic Load
Part Number 7832821_59f86_26495352
Backlash, Max 0.16 mm
Company Thomson Linear
[D1] 75 mm
[D4] 93 mm
[D5] 11 mm
[D8] 110 mm
Flange Included
[G] M8x1
[L] 85 mm
[L1] 16 mm
[L10] 8 mm
[L2] 85 mm
[L3] 22 mm
[L6] 22 mm
[L7] 16 mm
[L8] 85 mm
[L9] 10 mm
Load Lock Included
Maximum Static Load 188.7 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 6.35 mm
Ball Bearing Quantity 164
Diameter Major No
Dynamic Load 78.8 kN
Length No
Screw Diameter,Nominal 50 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
