FineLine Precision Rolled 7832818
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832818 is sold in North America. This same product is sold in Europe under part number 0215200306 Ball Nut Only, FK Style, 50 mm X 10 mm, Non-Preloaded, RH, Flange, 0.18 Max Backlash, 66.4 kN Dynamic Load
Part Number 7832818_56109_13225183
Backlash, Max 0.18 mm
Company Thomson Linear
[D1] 75 mm
[D4] 93 mm
[D5] 11 mm
[D8] 110 mm
Flange Included
[G] M8x1
[L] 92 mm
[L1] 13 mm
[L10] 8 mm
[L2] 92 mm
[L3] 7 mm
[L6] 7 mm
[L7] 16 mm
[L8] 85 mm
[L9] 9 mm
Load Lock No
Maximum Static Load 134.3 kN
Preload Non-Preloaded
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper No
Ball Bearing Diameter 7.144 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 66.4 kN
Length No
Screw Diameter,Nominal 50 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
