FineLine Precision Rolled 7832815
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832815 is sold in North America. This same product is sold in Europe under part number 0215900282 Ball Nut Only, FH Style, 40 mm X 40 mm, RH, Flange, Wiper, 0.18 Max Backlash, 80.0 kN Dynamic Load
Part Number 7832815_4a589_26116792
Backlash, Max 0.18 mm
Company Thomson Linear
[D1] 70 mm
[D4] 85 mm
[D5] 9 mm
[D8] 100 mm
Flange Included
[G] M8x1
[L] 104 mm
[L1] 25 mm
[L10] 7 mm
[L2] 104 mm
[L3] 17.5 mm
[L6] 17.5 mm
[L7] 14 mm
[L8] 75 mm
[L9] 10 mm
Load Lock Included
Maximum Static Load 178.6 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 7.144 mm
Ball Bearing Quantity 96
Diameter Major No
Dynamic Load 80 kN
Length No
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 40 mm
