FineLine Precision Rolled 7832812
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832812 is sold in North America. This same product is sold in Europe under part number 0215200317 Ball Nut Only, FH Style, 40 mm X 20 mm, RH, Flange, Wiper, 0.15 Max Backlash, 52.2 kN Dynamic Load
Part Number 7832812_4a584_34836667
Backlash, Max 0.15 mm
Company Thomson Linear
[D1] 63 mm
[D4] 78 mm
[D5] 9 mm
[D8] 93 mm
Flange Included
[G] M8x1
[L] 83 mm
[L1] 25 mm
[L10] 7 mm
[L2] 83 mm
[L3] 19.5 mm
[L6] 19.5 mm
[L7] 14 mm
[L8] 70 mm
[L9] 10 mm
Load Lock Included
Maximum Static Load 103.6 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 5.556 mm
Ball Bearing Quantity 156
Diameter Major No
Dynamic Load 52.2 kN
Length No
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
